Saltar al contenido principal
Inglés
Holandés
Paso 12
Slide an opening pick or thin pry tool underneath the top portion of the Lightning connector assembly flex cable, and begin separating it from the rear case. If necessary, use a hair dryer or apply an iOpener to heat the rear case and soften the adhesive, in order to make it easier to separate. If necessary, use a hair dryer or apply an iOpener to heat the rear case and soften the adhesive, in order to make it easier to separate.
  • Slide an opening pick or thin pry tool underneath the top portion of the Lightning connector assembly flex cable, and begin separating it from the rear case.
  • If necessary, use a hair dryer or apply an iOpener to heat the rear case and soften the adhesive, in order to make it easier to separate.
Insertar traducción aquí
