Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 12
Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board. During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place. During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
  • Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board.
  • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
Usa una herramienta de palanca delgada o pinzas para levantar y desconectar cuidadosamente los dos conectores del cable coaxial de la placa lógica.
Durante el reensamblaje, pueden ser difíciles de reconectar. Uno a la vez, sostén cada conector en su lugar sobre su zócalo y presiona hacia abajo con la parte plana de su spudger. El conector debe encajar en su lugar.
