Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up. Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
  • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
  • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
Los sensores en este paso son frágiles. Para aumentar las probabilidades de removerlos sin dañarlos, usa tu iOpener o secador de pelo para aplicar el calor sobre la porción superior de la pantalla antes de proceder. Alternativamente, agregar unas gotas de alcohol isopropílico y deja que penetre bajo los sensores antes de levantarlos.
Desliza un spudger debajo del cable flexible de sensor de luz ambiente y levanta el sensor de su zócalo.
