Saltar al contenido principal
Inglés
Español
Traduciendo paso 10
Paso 10
Boot your Tecra M5 from the maintenance floppy.  Select option 2: Repair initial config set.  This is supposed to shut down your system when it finishes, but it failed to terminate on my laptop.  Eventually I removed the floppy and rebooted my Tecra M5 laptop. The Settings/System/About dialog now shows the updated CPU. The device manager now shows the updated CPU.
Boot from the Floppy
  • Boot your Tecra M5 from the maintenance floppy. Select option 2: Repair initial config set. This is supposed to shut down your system when it finishes, but it failed to terminate on my laptop. Eventually I removed the floppy and rebooted my Tecra M5 laptop.
  • The Settings/System/About dialog now shows the updated CPU.
  • The device manager now shows the updated CPU.
  • Running the maintenance tool is also supposed to cure the problem of the fan running at full speed following a CPU upgrade.
Insertar traducción aquí
