Saltar al contenido principal
Inglés
Español
Paso 4
Remove the two screws adjacent to the translucent cover. Peel back the translucent cover.  Remove the two narrow white ribbon cables by gently pulling up on their collars to release the connector, and then sliding the ribbon cable out. Remove the metal cover held down by two screws.  Remove the additional screw to the right of the cover.  See second photo.
Remove Ribbon Cables
  • Remove the two screws adjacent to the translucent cover.
  • Peel back the translucent cover. Remove the two narrow white ribbon cables by gently pulling up on their collars to release the connector, and then sliding the ribbon cable out.
  • Remove the metal cover held down by two screws. Remove the additional screw to the right of the cover. See second photo.
  • Detach the keyboard ribbon cable from the connector by gently pulling up on the long white collar to open the connector. See third photo.
  • Detach the blue ribbon cable in the same manner.
  • Detach the white ribbon cable from the connector by gently pulling the gray connector collar toward you.
  • Detach the black display ribbon cable by gently pulling it straight up off the motherboard.
Insertar traducción aquí
