Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 15 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board. To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
  • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
  • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
Asegúrate de que la batería esté desconectada antes de desconectar o volver a conectar los cables en este paso.
Usa el extremo plano de un spudger o una uña para desconectar los dos conectores de pantalla inferior levantándolos de sus enchufes en la placa lógica.
Para volver a colocar los conectores de prensa, presione hacia abajo en un extremo hasta que encaje en su lugar, luego repita en el otro extremo. No presione hacia abajo en el medio. Si el conector está ligeramente desalineado, el conector puede doblarse, causando daños permanentes.
Si tienes una pantalla negra, líneas blancas en la pantalla o una falta total o parcial de respuesta táctil luego de reensamblar tu teléfono, trata de desconectar y con cuidado reconectar ambos cables y asegurarte de que estén bien encajados.
