Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 17 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
  • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Antes de comenzar, descarga la batería de tu iPhone por debajo del 25%. Una batería de litio cargada puede prenderse fuego y/o explotar si se la pincha accidentalmente.
Apague su iPhone antes de comenzar el desmontaje.
Abrir la pantalla del iPhone pondrá en peligro sus sellos a prueba de agua. Tenga especial cuidado de no exponer su iPhone a daños por líquidos después de completar su reparación.
Retire los dos tornillos "pentalobe" de 3,4 mm del borde inferior del Iphone
[* icon_caution] Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
[* black] Power off your iPhone before beginning disassembly.
[* icon_caution] Opening the iPhone's display will compromise its waterproof seals. Take extra care not to expose your iPhone to liquid damage after completing your repair.
[* red] Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
[* icon_note] Opening the iPhone's display will compromise its waterproof seals. Have [product|IF333-011|replacement seals|new_window=true] ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
