Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 23
It's important to disconnect the battery before you proceed further. Detaching or connecting the display cables with the battery plugged in can cause a short that will destroy touchscreen functionality.
  • It's important to disconnect the battery before you proceed further. Detaching or connecting the display cables with the battery plugged in can cause a short that will destroy touchscreen functionality.
  • To disconnect the battery:
  • First, securely prop up the display so that it won't fall or strain the display cables while you work.
  • Then, remove the nine Phillips screws securing the logic board EMI shield:
  • Eight 1.2 mm screws
  • One 2.4 mm screw
Insertar traducción aquí
