Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 22
Paso 22
MacBook Pro with Retina Display 15" Mid 2012 Repairability Score: 1 out of 10 (10 is easiest to repair). Proprietary pentalobe screws prevent you from gaining access to anything inside.
  • MacBook Pro with Retina Display 15" Mid 2012 Repairability Score: 1 out of 10 (10 is easiest to repair).
  • Proprietary pentalobe screws prevent you from gaining access to anything inside.
  • As in the MacBook Air, the RAM is soldered to the logic board. Max out at 16GB now, or forever hold your peace—you can't upgrade.
  • The proprietary SSD isn't upgradeable either (yet), as it is similar but not identical to the one in the Air. It is a separate daughtercard, and we’re hopeful we can offer an upgrade in the near future.
  • The lithium-polymer battery is glued rather than screwed into the case, which increases the chances that it'll break during disassembly. The battery also covers the trackpad cable, which tremendously increases the chance that the user will shear the cable in the battery removal process.
  • The display assembly is completely fused, and there’s no glass protecting it. If anything ever fails inside the display, you will need to replace the entire extremely expensive assembly.
Puntaje de Reparabilidad de la MacBook Pro con Pantalla de Retina 15" de Mediados de 2012: 1 de 10 (10 es lo más fácil de reparar).
Los tornillos pentalobe patentados previenen el acceso a la parte interior.
Como en la MacBook Air, la RAM está soldada a la placa lógica. Consigue la máxima a 16GB ahora, o calla para siempre—no puedes agregar más memoria.
La SSD patentada no se puede mejorar tampoco (aun), ya que es similar pero no idéntica a la que tiene la Air. Es una tarjeta hija separada, y esperamos que podamos ofrecer una actualización en el futuro cercano.
La batería de polímero de litio está pegada en vez de atornillada en la caja, lo que aumente las chances de que se rompa durante el desmontaje. La batería también cubre el cable del trackpad, que tremendamente aumenta la chance de que el usuario corte el cable en el proceso de remover la batería.
El ensamblaje de pantalla está fusionado y no hay vidrio que lo proteja. Si algo falla dentro de la pantalla alguna vez, tendrás que reemplazar el ensamblaje entero completamente costoso.
