Saltar al contenido principal
Inglés
Español
Paso 7
Once all the server juice has been filtered by the power filter, its gets converted to the correct voltage by the power converter. The power converter is actually two identical modules stacked on top of each other, using the standoffs between them as a power relay. The output of the power supply is 12 volts, 40 amps, for a whopping 480 watts.
  • Once all the server juice has been filtered by the power filter, its gets converted to the correct voltage by the power converter.
  • The power converter is actually two identical modules stacked on top of each other, using the standoffs between them as a power relay.
  • The output of the power supply is 12 volts, 40 amps, for a whopping 480 watts.
Insertar traducción aquí
