Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Now that the cable has been removed you can slide it through the opening and detach the glass. Be careful as you pull the cable through the opening. The cable is easily damaged. Once the cable is pushed through the slot, the glass can be fully removed.
  • Now that the cable has been removed you can slide it through the opening and detach the glass.
  • Be careful as you pull the cable through the opening. The cable is easily damaged.
  • Once the cable is pushed through the slot, the glass can be fully removed.
Insertar traducción aquí
