Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Using a plastic opening tool, carefully pry up the bottom of the display glass. Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone. As you work, the adhesive may cool and harden.  You may need to heat up the glass again as you work your way around the screen.
  • Using a plastic opening tool, carefully pry up the bottom of the display glass.
  • Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone.
  • As you work, the adhesive may cool and harden. You may need to heat up the glass again as you work your way around the screen.
Insertar traducción aquí
