Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 2
Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button. Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
  • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
  • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
  • Lift the tabs located on the bottom of the phone to continue removing the back cover.
Insertar traducción aquí
