Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the four 5.0 mm T5 Torx screws from the corners of the phone. Remove three 5.5 mm T5 Torx screws from the back of the phone. Lift up the black rubber flap near the SD card slot.
  • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
  • Remove three 5.5 mm T5 Torx screws from the back of the phone.
  • Lift up the black rubber flap near the SD card slot.
  • Remove the single 5.5 mm T5 Torx screw beneath the flap.
  • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
Insertar traducción aquí
