Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 7
Pull the SATA data cable straight up off the logic board.
  • Pull the SATA data cable straight up off the logic board.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
Insertar traducción aquí
