Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet. The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is still attached by its SATA cable; do not attempt to fully remove it from the iMac yet.
Levante el disco duro del borde más cercano a la placa y extráigalo ligeramente de su alojamiento.
El disco duro todavía estará conectado por su cable SATA; No intente extraerlo completamente todavía.
