Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 25 guías que incluyan este paso.
Inglés
Español
Paso 3
Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
  • Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
  • In newer model iMacs these are 7.2 mm T8 Torx screws.
  • During reassembly, be careful not to trap the power button wire behind the board.
Remueve los dos tornillos Torx T10 de 7.2 mm que aseguran la fuente de energía a la carcasa posterior.
En los nuevos modelos de iMac son tornillos Torx T8 de 7.2 mm.
[* red] Remove the two 7.2 mm T10 Torx screws securing the power supply to the rear enclosure.
[* icon_note] In newer model iMacs these are 7.2 mm T8 Torx screws.
+ [* icon_reminder] During reassembly, be careful not to trap the power button wire behind the board.
