Saltar al contenido principal
Inglés
Español
Paso 7
Disconnect trackpad. Use a spudger to ease topcase free of bottom case. Slide topcase toward trackpad and then lift up. Resistance can be felt from magnets on topcase. Your laptop should now look like this; middle photo is the remaining logicboard and bottom case, the last photo is the topcase cover.
  • Disconnect trackpad.
  • Use a spudger to ease topcase free of bottom case. Slide topcase toward trackpad and then lift up. Resistance can be felt from magnets on topcase.
  • Your laptop should now look like this; middle photo is the remaining logicboard and bottom case, the last photo is the topcase cover.
Desconecte el trackpad.
Use un spudger para facilitar la funda libre de la caja inferior. Deslice la funda hacia el trackpad y luego levántela. La resistencia se puede sentir de los imanes en la funda.
Su Laptop debería ahora lucir así; la foto media es el Logicboard restante y la caja inferior, la foto pasada es la cubierta del caso.
