Saltar al contenido principal
Inglés
Español
Paso 3
Turn laptop over and open the screen fully. Take care as the screen is still connected to the logic board via black cable on right hinge. Use a spudger to release the silver and black plastic cover that forms the hinge covers. Start at one side nearest a hinge and work along the rear of the case, there are 5 tabs to release along the keyboard edge. Disconnect LCD cable by lifting straight upwards using the black plastic tabs on the top of the LCD connector. You may need to use a spudger to loosen the connection along the uppermost edge-not along the logicboard.
  • Turn laptop over and open the screen fully. Take care as the screen is still connected to the logic board via black cable on right hinge.
  • Use a spudger to release the silver and black plastic cover that forms the hinge covers. Start at one side nearest a hinge and work along the rear of the case, there are 5 tabs to release along the keyboard edge.
  • Disconnect LCD cable by lifting straight upwards using the black plastic tabs on the top of the LCD connector. You may need to use a spudger to loosen the connection along the uppermost edge-not along the logicboard.
  • Remove 2 screws from left and right hinges.
  • Remove 2 screws securing topcase to rear of battery tray.
Voltear el portátil y abrir la pantalla completamente. Tenga cuidado ya que la pantalla todavía está conectada a la placa lógica a través de cable negro en la bisagra derecha.
Utilice un spudger para liberar la cubierta de plástico plateada y negra que forma las cubiertas de la bisagra. Comience en un lado más cercano a una bisagra y trabaje a lo largo de la parte posterior de la caja, hay 5 lengüetas para lanzar a lo largo del borde del teclado.
Desconecte el cable LCD levantándolo hacia arriba usando las lengüetas de plástico negro en la parte superior del conector LCD. Es posible que tenga que utilizar un spudger para aflojar la conexión a lo largo del borde superior-no a lo largo del Logicboard.
Quite los 2 tornillos de las bisagras izquierda y derecha.
Retire los 2 tornillos que sujetan la funda a la parte trasera de la bandeja de la batería.
