Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 4
Rotate the top of the drive toward yourself, then lift the hard drive straight up off its lower pins. The hard drive is still connected via the SATA cables.
  • Rotate the top of the drive toward yourself, then lift the hard drive straight up off its lower pins.
  • The hard drive is still connected via the SATA cables.
  • When reinstalling your hard drive, be careful not to push the rubber grommets through the openings in the chassis with the lower hard drive pins as retrieving them may require logic board removal.
Insertar traducción aquí
