Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 3
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly. Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display. Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
  • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
  • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Insertar traducción aquí
