Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Use a spudger to disconnect ribbon cable(s) 1, 2, and 3. Just a reminder. The 3rd cable is actually connected to the board by a port, which requires an inset connector. Lift up the black tab on the back of the inset connector port, and then the 3rd ribbon should slide right out.
  • Use a spudger to disconnect ribbon cable(s) 1, 2, and 3.
  • Just a reminder. The 3rd cable is actually connected to the board by a port, which requires an inset connector.
  • Lift up the black tab on the back of the inset connector port, and then the 3rd ribbon should slide right out.
Usa un spudger para desconectar los cables de cinta 1, 2 y 3.
Simplemente un recordatorio. El 3er cable está realmente conectado a la placa mediante un puerto, que requiere insertar un conector.
Levanta la pestaña negra en la parte posterior del puerto del conector de inserción, y luego el 3er Flex debería deslizarse hacia afuera.
