Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Attach the small suction cup to the iPhone, above the home-button. Grip the suction cup, and start lifting the display slowly, and gently, making sure not to remove the display completely. There are still ribbon cables connecting the display assembly to the motherboard.
  • Attach the small suction cup to the iPhone, above the home-button.
  • Grip the suction cup, and start lifting the display slowly, and gently, making sure not to remove the display completely. There are still ribbon cables connecting the display assembly to the motherboard.
  • In some cases, the suction cup just won't adhere to the screen! You could use a heavy duty suction cup, or duct tape to pry off the screen. However, if you do not plan on replacing the screen, I do not suggest that you use duct tape.
  • Lift the display to a 45 degree angle.
Coloca la ventosa pequeña en el iPhone, por encima del botón de inicio.
Sujeta la ventosa y empieza a levantar la pantalla lentamente con cuidado, asegurándote de no quitarla por completo. Todavía hay Flexs que conectan el ensamblaje de la pantalla a la placa base.
En algunos casos, la ventosa simplemente no se adhiere a la pantalla! Puedes usar una ventosa de alta resistencia o una cinta adhesiva para sacar la pantalla. Sin embargo, si no planeas reemplazar la pantalla, no sugiero que uses cinta adhesiva.
Levanta la pantalla a un ángulo de 45 grados.
