Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 14 guías que incluyan este paso.
Inglés
Español
Paso 7
The fingerprint sensor cable connects the phone to the rear glass near the main camera. The cable is very short and should disconnect as the rear glass is removed. As you lift the glass, peek in to be sure the orange cable with a blue connector has disconnected.
  • The fingerprint sensor cable connects the phone to the rear glass near the main camera. The cable is very short and should disconnect as the rear glass is removed.
  • As you lift the glass, peek in to be sure the orange cable with a blue connector has disconnected.
  • Use the opening picks to slice through any remaining adhesive and open the phone slightly.
  • If the fingerprint sensor cable seems snagged or stays taut do not open the phone any further. Disconnect the connector with the point of a spudger before proceeding.
  • During reassembly, in order to reconnect the fingerprint sensor cable, first angle the back cover into position until the cable connector lines up perfectly over its socket. Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
  • Remove the glass from the phone.
El cable del sensor de huellas conecta al teléfono con el cristal trasero, cerca de la cámara principal. El cable es muy corto y se debería desconectar mientras se retira el cristal trasero.
Mientras levantas el cristal trasero, asegúrate de que el cable naranja con el conector azul se ha desconectado.
Utiliza las púas para eliminar cualquier resto de adhesivo que haya quedado y abre con cuidado el teléfono.
Si el cable del sensor de huellas está conectado o trabado, no continúes abriendo el teléfono. Desconecta el conector antes de continuar.
Durante el montaje, para reconectar el cable del sensor de huellas alinea el cristal trasero hasta que el cable del sensor esté sobre el conector de la placa. Entonces, usa la parte plana del spudger para presionarlo cuidadosamente hacia abajo y conectarlo.
Quita el cristal del teléfono.
