Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 14 guías que incluyan este paso.
Inglés
Español
Paso 7
Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
  • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
  • The location of this screw may vary between models.
Usa el extremo plano de un spudger para levantar con cuidado la tapa de rosca de goma de la cabeza del tornillo elevado cerca del conector MagSafe 2.
[* black] Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
[* icon_note] The location of this screw may vary between models.
