Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 13 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Remove the following three screws securing the right speaker to the upper case: One 5.6 mm T5 Torx screw
  • Remove the following three screws securing the right speaker to the upper case:
  • One 5.6 mm T5 Torx screw
  • One 6.9 mm T5 Torx screw
  • One 2.6 mm T5 Torx screw
  • Remove the right speaker from the MacBook Pro.
  • The speaker is secured to the case with some light adhesive.
Retira los siguientes tres tornillos que sujetan el altavoz derecho a la carcasa superior:
Un tornillo Torx T5 de 5,6 mm
Un tornillo Torx T5 de 6,9 ​​mm
Un tornillo Torx T5 de 2,6 mm
Retira el altavoz derecho de la MacBook Pro.
[* black] Remove the following three screws securing the right speaker to the upper case:
[* red] One 5.6 mm T5 Torx screw
[* orange] One 6.9 mm T5 Torx screw
[* yellow] One 2.6 mm T5 Torx screw
[* black] Remove the right speaker from the MacBook Pro.
[* icon_note] The speaker is secured to the case with some light adhesive.
