Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 33 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board. On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal. Carefully lift the I/O board and remove it from the lower case.
  • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
  • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
  • Carefully lift the I/O board and remove it from the lower case.
Retira los dos tornillos Torx T5 de 3,1 mm que sujetan la placa de E / S a la placa lógica.
Levanta con cuidado la placa de E / S y retírala de la carcasa inferior.
[* red] Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
[* orange] On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
[* black] Carefully lift the I/O board and remove it from the lower case.
