Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 3
Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside. Do not try to remove the display panel completely as it is still connected to the rest of the device. While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
  • Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside.
  • Do not try to remove the display panel completely as it is still connected to the rest of the device.
  • While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
Insertar traducción aquí
