Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the two 5.3 mm T6 torx screws from the LCD connector. Firmly grasp the pull tab on top of the connector and pull it straight up out of its port. Make sure that you are pulling the tab and not the connector cable.
  • Remove the two 5.3 mm T6 torx screws from the LCD connector.
  • Firmly grasp the pull tab on top of the connector and pull it straight up out of its port.
  • Make sure that you are pulling the tab and not the connector cable.
Insertar traducción aquí
