Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 6
With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing. The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing. The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing.
  • With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing.
  • The nob that previously held the camera strap will no longer be attached to the camera once you remove the camera casing. When putting the camera back together, remember to put the nob back into position before replacing the casing.
Insertar traducción aquí
