Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 5
With the LCD lifted, disconnect the LCD cable by pulling down. The LCD cable is attached to the underside of the power supply; be careful where you put your fingers so you don't get zapped by a capacitor.
  • With the LCD lifted, disconnect the LCD cable by pulling down.
  • The LCD cable is attached to the underside of the power supply; be careful where you put your fingers so you don't get zapped by a capacitor.
  • On reassembly, you may find it helpful to remove the power supply, reconnect the LCD power cable, and then reinstall the power supply.
  • Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
Insertar traducción aquí
