Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 4
Lay the iMac down on a table before you remove the LCD so that it doesn't fall. Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
  • Lay the iMac down on a table before you remove the LCD so that it doesn't fall.
  • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
  • Lift the right side of the display panel a few inches up from the iMac.
  • Do not lift the LCD all the way up; there are still connectors attaching the LCD to the internals.
Insertar traducción aquí
