Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 21 guías que incluyan este paso.
Inglés
Español
Paso 4
Rotate the mini so that the SuperDrive slot loading mechanism is facing you. Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
  • Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
  • Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
  • Use tweezers to grab the connector (as seen in the picture), not the wires.
  • The connector is located under the optical drive opening, next to the PRAM battery.
Insertar traducción aquí
