Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 3
Insert an opening pick between the trackpad ribbon cable and the battery. Carefully slide your pick underneath the length of the ribbon cable to separate the adhesive securing it to the battery. The ribbon cable is easily damaged. If necessary, use a little heat from an iOpener or hair dryer to soften the adhesive so you can remove it with less force.
  • Insert an opening pick between the trackpad ribbon cable and the battery.
  • Carefully slide your pick underneath the length of the ribbon cable to separate the adhesive securing it to the battery.
  • The ribbon cable is easily damaged. If necessary, use a little heat from an iOpener or hair dryer to soften the adhesive so you can remove it with less force.
Introduce una pua de apertura entre el cable cinta del panel táctil y la batería.
Con cuidado desliza tu pua por debajo del largo del cable cinta para separar el adhesivo que lo sujeta a la batería.
El cable cinta puede dañarse fácilmente. Si es necesario, usa algo de calor de un iOpener o secador de pelo para ablandar el adhesivo así lo puedes remover con menos fuerza.
