Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way. The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable. To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
  • The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable.
  • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
Usa una palanca Spudger antiestático o pinzas para desconectar los tres conectores de la antena Airport y doblarlos hacia arriba y quitarlos del camino.
El punto de conexión del cable es muy frágil. Ten cuidado al levantar solo el conector, y no el cable.
Para re-conectar, alinea cuidadosamente el conector en su posición sobre la antena Airport, y presionalo hacia abajo firmemente con la base de tu palanca spudger antiestático.
