Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 5
Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body. Slide the spudger along the gap, applying downward pressure to separate the two components.
  • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
  • Slide the spudger along the gap, applying downward pressure to separate the two components.
  • You should hear popping sounds as you slide the spudger along the edge.
  • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
Insertar traducción aquí
