Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery. The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience. The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
  • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
Insertar traducción aquí
