Saltar al contenido principal
Inglés
Español
Paso 7
Remove each cable and connection to the logic board. Next, remove the screws holding the motherboard to the bottom case. There may be a screw in this area, there was not in the computer I worked on.
Removing the Mother Board
  • Remove each cable and connection to the logic board.
  • Next, remove the screws holding the motherboard to the bottom case.
  • There may be a screw in this area, there was not in the computer I worked on.
  • Remove the screw holding the wifi card in place. Pull the wifi card out.
Retira cada cable y conexión a la placa lógica.
A continuación, retira los tornillos que sujetan la placa madre a la carcasa inferior.
Puede que exista un tornillo en esta área, no había en la computadora en la que trabajé.
Retira el tornillo que sujeta la tarjeta wifi en su lugar. Saca la tarjeta wifi.
