Saltar al contenido principal
Inglés
Español
Paso 6
Flip your computer back over and open the display. Using a sputter, opening tool, guitar pick, or card pry up on the top case between the frame and itself. Follow all the way around the top case gently, until the keyboard is able to be lifted freely. NOTE* Do not lift the keyboard off until the next step in which we pull the ribbon cable connections.
Remove the Top Case
  • Flip your computer back over and open the display. Using a sputter, opening tool, guitar pick, or card pry up on the top case between the frame and itself.
  • Follow all the way around the top case gently, until the keyboard is able to be lifted freely.
  • NOTE* Do not lift the keyboard off until the next step in which we pull the ribbon cable connections.
  • Using your spudger, or prying tool lift the releases for each ribbon cable. *Be cautious when removing and handling ribbon cables as they are very fragile.
  • Lastly, remove the last two ribbon cables located at the top of the keyboard.
Insertar traducción aquí
