Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 4
Slide the opening pick up both sides of the device in the small space between the midframe and the rear case to release the clips holding it in place. Note that the clips are not released by sliding through them, but rather the inward pressure the opening pick creates as it enters the gap around them. If the clasps fail to come undone, try pushing the edge you're working on inward with your hand, or using a thicker tool like a spudger.
  • Slide the opening pick up both sides of the device in the small space between the midframe and the rear case to release the clips holding it in place.
  • Note that the clips are not released by sliding through them, but rather the inward pressure the opening pick creates as it enters the gap around them.
  • If the clasps fail to come undone, try pushing the edge you're working on inward with your hand, or using a thicker tool like a spudger.
  • Do not attempt to remove the midframe yet! There is still a fragile ribbon cable underneath connecting the earpiece speaker to the motherboard.
Insertar traducción aquí
