Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 16 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the seven T8 Torx screws from the lower case. Using your thumbs, slide the lower case toward the front of the computer.
  • Remove the seven T8 Torx screws from the lower case.
  • Using your thumbs, slide the lower case toward the front of the computer.
  • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
  • Lift the lower case off.
Insertar traducción aquí
