Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 3
Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis. If your display is cracked, cover it with packing tape to help the suction cup adhere and prevent glass shards from popping loose.
  • Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
  • If your display is cracked, cover it with packing tape to help the suction cup adhere and prevent glass shards from popping loose.
  • You may need to apply more heat if this doesn't come up. Don't be impatient, this will take time. Once you can gently insert a tool in the gap, move on to the next step.
Usa una manija de succiónpara levantar la pantalla y crear un pequeño espacio entre la pantalla y el chasis del teléfono.
Si tu pantalla está agrietada, cúbrela con cinta de embalaje para ayudar a que la ventosa se adhiera y evitar que los fragmentos de vidrio se suelten.
[* black] Use a [product|IF145-361|suction handle|new_window=true] to pull up on the display and create a slight gap between the display and the phone's chassis.
[* icon_note] If your display is cracked, [guide|103487|cover it with packing tape|stepid=193572|new_window=true] to help the suction cup adhere and prevent glass shards from popping loose.
[* black] You may need to apply more heat if this doesn't come up. Don't be impatient, '''this will take time'''. Once you can gently insert a tool in the gap, move on to the next step.
