Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 9
Use a spudger to pry up the display cable connector, freeing the display.
  • Use a spudger to pry up the display cable connector, freeing the display.
  • On reassembly, gently snap one side in, then the other.
  • Do not force this type of connector into place, as damage can occur. (You will need to feel a light snap, but force beyond this will permanently damage your connector.)
Usa un spudger para levantar el conector del cable de la pantalla, liberando la pantalla.
[* black] Use a spudger to pry up the [guide|25629|display cable connector|stepid=70308|new_window=true], freeing the display.
[* icon_reminder] On reassembly, gently snap one side in, then the other.
[* icon_caution] Do not force this type of connector into place, as damage can occur. (You will need to feel a light snap, but force beyond this will permanently damage your connector.)
