Saltar al contenido principal
Inglés
Español
Paso 6
If you have  a stereo microscope you should go over the board to look for damaged components or broken solder joints.  If no microscope is available this would be a good time to loosely reassemble the unit and see if you have a good result.  If the unit has visible issues board level you may want to consider finding a professional  repair option.
Inspection, Inspection and more Inspection.
  • If you have a stereo microscope you should go over the board to look for damaged components or broken solder joints. If no microscope is available this would be a good time to loosely reassemble the unit and see if you have a good result. If the unit has visible issues board level you may want to consider finding a professional repair option.
Insertar traducción aquí
