Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 3
Flip the console over so the bottom is facing up. Use a T8 Torx Security  screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left. Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  • Flip the console over so the bottom is facing up.
  • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
  • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
Mueva la consola hacia arriba para que la parte inferior quede hacia arriba.
Utilice un destornillador de seguridad Torx T8 para quitar los tres tornillos negros de 7 mm en el panel posterior.
Retire la cubierta inferior de la misma manera que la cubierta superior. Sujete la cubierta en ambos lados y tire hacia arriba hasta que haga clic. A continuación, deslice la tapa.
[* black] Flip the console over so the bottom is facing up.
-[* red] Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
-[* black] Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off.
+[* red] Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or ***one*** 7mm screw (the middle one) with ''7100-series'' models ***and*** the warranty sticker to the left.
+[* black] Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; ***''With 7100-series models,''*** pay attention to the two clips that replace the corresponding screws.
