Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Use a T8 Torx Security screwdriver to remove five screws from the rear of the device. Two 31mm screws. Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
  • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
  • Two 31mm screws.
  • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
  • Remove the metal plate by pulling it up.
Utilice un destornillador de seguridad Torx T8 para quitar los cinco tornillos de la parte posterior del dispositivo.
Dos tornillos de 31mm.
Three 10mm screws.
Retire la placa de metal tirando de ella.
[* black] Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
[* red] Two 31mm screws.
- [* orange] Three 10mm screws.
+ [* orange] Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
[* black] Remove the metal plate by pulling it up.
