Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 4
Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate. Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate. Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
  • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
  • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
