Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard. Use a Phillips #1 screwdriver to remove the ten 5.5mm screws. Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
  • If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard.
  • Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
  • Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
Insertar traducción aquí
