Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 5
Heat the bottom edge with an iOpener for two minutes. Insert a pick near the right edge where you have already loosened the adhesive.
  • Heat the bottom edge with an iOpener for two minutes.
  • Insert a pick near the right edge where you have already loosened the adhesive.
  • Carefully guide the pick around the corner.
  • Slide the pick along the bottom edge to slice through the adhesive.
  • Do not slice deeper than 8.5 mm (1/3") or you will damage the display cable.
Insertar traducción aquí
