Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 3
Slide the opening clip across the top edge to slice through the adhesive. Be sure not to cut deeper than 13 mm (0.5 inches) or you will damage the display. Leave an opening pick in the edge to prevent the adhesive from resealing.
  • Slide the opening clip across the top edge to slice through the adhesive.
  • Be sure not to cut deeper than 13 mm (0.5 inches) or you will damage the display.
  • Leave an opening pick in the edge to prevent the adhesive from resealing.
Insertar traducción aquí
